Images Manager dialog box
Use the Stored Images dialog box to store images in the database for use by any user. You can store up to 20 images per database.
Thumbnail: A representation of the stored image.
Default: Determines the image which will be used as default when you select Stored Images in Page Setup.
Name: The name of the stored image file.
Purpose: The purpose of the stored image.
Description: A description of the stored image.
Select: Selects an image to use.
Add: Click to upload a new image to the database.
Delete: Click to delete an image you no longer need.
Last Published Friday, December 12, 2025
