General tab - Modify Template or View Template dialog box
Import
Select a currency: Click to select a currency to use for values in cost fields.
Note
The following options are available for MPX format:
Schedule project after import: Mark to automatically schedule the project in P6 Professional after the import.
Summarize project after import to WBS level: Mark to automatically summarize the project in P6 Professional after the import. Select the level of WBS data to which the project should be summarized.
The following options are available for the XML format:
Import Microsoft Project summary task as WBS summary task: Mark to import a summary task from Microsoft Project as a P6 Professional WBS summary task in addition to the WBS hierarchical element.
Select the Microsoft Project baseline to use for planned/budgeted values: Mark to select a Microsoft Project baseline for planned or budgeted values, with the option to select one of Microsoft's 10 baselines. Selecting 0 indicates the current project baseline.
Last Published Friday, December 12, 2025
