General tab - Project Threshold Details
Threshold Parameter: The specific parameter, or condition, that will be monitored. To select a parameter, click
Lower Threshold: The selected threshold's lower numeric value. Type a value.
Upper Threshold: The selected threshold's upper numeric value. Type a value.
Note
- When connected to a P6 EPPM database: If the Use the assigned calendar to specify the number of work hours for each time period checkbox is marked (the Application Settings in P6), then the module converts, stores, and displays the threshold values using the hours per time period defined in the default global calendar. Otherwise, the hours per time period from the Application Settings in P6 are used.
- When connected to a P6 Professional database: If the Use the assigned calendar to specify the number of work hours for each time period checkbox is marked (Admin Preferences, Time Periods tab), then the module converts, stores, and displays the threshold values using the hours per time period defined in the default global calendar. Otherwise, the hours per time period from the Admin Preferences dialog box are used.
WBS to Monitor: The code for the work breakdown structure (WBS) element to which the selected threshold applies. To select a WBS element, click
Detail to Monitor: The level at which you want to monitor the selected threshold: WBS or activity. To select a monitor level, click the down arrow.
Responsible Manager: The manager within the organizational breakdown structure (OBS) who is responsible for the selected threshold's issues. To select a responsible manager, click
Tracking Layout: The tracking layout that will be used to display the selected threshold's issues. To select a tracking layout, click
Status: The selected threshold's status. To select a status, click the down arrow.
Note
Issues are not identified for disabled thresholds.
Issue Priority: The priority level for issues generated by the selected threshold. To select a priority level, click the down arrow.
Last Published Friday, December 12, 2025
