Group activities by field
  1. Choose Project, Activities, then choose View, Group and Sort By.
  2. In the Group By section, click the cell, then select the item by which you want to group.
  3. Click Sort, then select a sort order for the group. Click OK.
  4. To change a grouping band's attributes, such as the color and font, double-click the appropriate Font & Color field.
  5. To group by additional items (up to 20 levels), repeat step 2.
Tip:
Last Published Thursday, April 3, 2025
