Importing Options -- Resources
If resource security is enabled (you have limited or no resource access), the following restrictions apply when importing resources:
A) Limited resource access:
Keep Existing
Update Existing
Insert New
Do Not Import
New resource
See Note.
The resource is added as a child under your root resource node.
Existing resource (under your root node)
The resource data is updated.
The resource is added as a child under your root resource node. Resource ID is appended by "-1". (For example, if the Resource ID is "Labor", the new Resource ID will be "Labor-1")
Existing resource (outside your root node)
Note
For XML:
B) No resource access:
If you have no resource access, you cannot import resources.
Last Published Friday, December 12, 2025
