Layout Toolbar
Use the Layout toolbar to customize the layout of the active window and to access user preferences. This toolbar is displayed by default.
The following table provides information about each available icon on the toolbar.
Icon | Function | Displays by default? | Enabled when active window is: | Corresponding menu command |
| Opens the New Layout dialog box. Use the New Layout dialog box to create a custom tracking layout. | No | Tracking | View > Layout > New |
| Opens the Open Layout dialog box. Use the Open Layout dialog box to select and display a different layout, and to import and export layouts. | No | Activities, Projects, Resource Assignments, WBS, Tracking | View > Layout > Open |
| Saves the currently displayed layout. | No | Activities, Projects, Resource Assignments, Work Breakdown Structure, Tracking | View > Layout > Save |
| Saves the currently displayed layout as a new layout. | No | Activities, Projects, Resource Assignments, Work Breakdown Structure, Tracking | View > Layout > Save As |
| Opens the Bars dialog box. Use the Bars dialog box to specify the style and labels for the bars in a Gantt Chart. This icon is enabled when you display a Gantt Chart in the active window. | Yes | Activities, Projects, Tracking, Work Breakdown Structure | View > Bars |
| Enables you to select a predefined column layout or to customize the columns that display in the active window. The available options vary for each window. To customize columns, click the icon, then choose Customize. This icon is enabled when you display a table view in the active window. | Yes | All except Reports | View > Columns |
| Opens the Timescale dialog box. Use the Timescale dialog box to specify the timescale you want to display in the current Gantt Chart, profile, or spreadsheet layout. | Yes | Activities, Projects, Resource Assignments, Tracking, Work Breakdown Structure | View > Timescale |
| Enables you to select a predefined filter or to create a custom filter. The available options vary for each window. To create a custom filter, click the icon, then choose Customize. | Yes | All except Work Breakdown Structure and Project Expenses | View > Filter By |
| Enables you to select a predefined grouping and sorting option, or to specify your own grouping and sorting criteria. The available options vary for each window. To customize grouping and sorting, click the icon, then choose Customize. | Yes | All | View > Group and Sort By |
| Numbers each row in the Activities view. This icon is enabled when you display an Activity table, Gantt Chart, or Activity Usage Spreadsheet in the active window. | Yes | Activities | View > Line Numbers |
| Opens the Table, Font and Row dialog box. Use the Table Font and Row dialog box to change the appearance of text, color, and the height of rows in your display. The available options vary for each window. | Yes | All | View > Table Font and Row |
| Opens the User Preferences dialog box. Use the User Preferences dialog box to specify your settings and preferences, including how to display time, date, and currency information. You can also set options to send email, specify startup options, and change your password. | Yes | All | Edit > User Preferences |
Tip
- To show icons on the toolbar that do not display by default, you must customize the toolbar.
- The icons on this toolbar do not have corresponding shortcut keys.
- You can also click the Display or Layout options bar in the active window to access most of the functionality available from this toolbar.
Related Topics
Save a layout in the Activities or Resource Assignments window
Save a layout in the Projects or Work Breakdown Structure window
Change a layout's timescale format
Last Published Friday, December 12, 2025
