Level selected resources
  1. Choose Tools, Level Resources.
  2. Clear the Level All Resources checkbox to level only a subset of all the resources.
  3. Click Select Resources.
  4. Mark the checkbox in the Level column next to each resource you want to level, then click OK.
  5. Click Level.
    Note
    • If the Level All Resources checkbox is marked, all the resources will be leveled regardless of the resource selection defined under the Select Resources button.
Last Published Friday, December 12, 2025
