Login to Primavera P6 Professional dialog box
Login names and passwords are case-sensitive. Your login name can be up to 255 characters in length; your password can be up to 20 characters in length.
Login Name: Enter your login name.
Password: Enter your password.
Work Offline: Select this option to work offline with the data cached in your local cache database. Clear this option if you have previously been working offline and want to connect to the CloudConnect database. To see this option, select a Cloud Connect database.
Advanced section
Database: Select a database to connect to.
Language: Select the language in which to display data in menus, dialog boxes, and messages.
Reinitialize local cache: Use this option to discard the existing data in your local cache and download fresh data from the server. This is useful to remove projects you are no longer interested in from the local cache. If you select this option, P6 Professional will take longer to open than normal. To see this option, select a Cloud Connect database.
Clear SSO browser data: Use this option to clear the embedded browser cache used by P6 Professional when connecting to a CloudConnect database with SAML.
Edit database configuration: Click to configure your database.
Last Published Friday, December 12, 2025
