Printing a reflection difference report
The Preview Changes to Project dialog box provides a print function that allows you to print a report that lists the differences between the reflection and the source project.
  1. In the Projects view, right click on the reflection that you want to print a difference report.
  2. In the context menu, click Merge Reflection into Source Project. If there are any changes to merge, the system responds by displaying the Preview changes to project dialog box.
  3. In the Group Changes By, choose how you would like group the changes.
  4. Expand or collapse the nodes as you would like the information to be displayed in the printout.
  5. Right click anywhere inside the grid and choose Print Preview from the context menu.
  6. To set the default printer, paper size, and page orientation, click
  7. Click to print the difference report.
Last Published Friday, December 12, 2025
