Project Tailoring Rationale dialog box (P6 Professional Only)
Use the Project Tailoring Rationale dialog box to view and edit explanations of the open project, such as a history or notable events.
Rationale History: Previous rationales for the open project's features according to date and author.
Rationale Notes: New rationales. You can type in this field.
Add: Closes this dialog box and saves the rationale you entered.
Last Published Friday, December 12, 2025
