Resource Curves dialog box
Use the Resource Curves dialog box to add, delete, or modify resource curves. Curves are used to allocate resources and costs over the duration of an activity.
Display Options bar: Click to search for a specific curve or to preview how the dialog box will print.
Resource Curve Name: Lists the default and global resource curves. The ten default curves cannot be edited.
Add: Click to add a global resource curve. You are prompted to select one of the existing curves from which to copy the curve value percentages. You can add an unlimited number of global resource curves.
Delete: Click to delete a global resource curve. You cannot delete default curves.
Modify: Click to change curve value percentages for global resource curves. You cannot modify default curves.
Last Published Friday, December 12, 2025
