Select Default Project Calendar dialog box
Use the Select Default Project Calendar dialog box to assign a global or project calendar.
Display Options bar: Lists options for changing the calendars display.
Search: Type a calendar name to display a filtered list of names beginning with the letters typed.
Calendar Name: Lists names of project or global calendars, depending on your current display. To sort the display, click the Calendar Name column label.
Default: If your current display is Global Calendars, indicates the default global calendar. To sort the display, click the Default column label.
Select: Assigns the selected calendar to the selected project.
Clear: Removes the selected calendar from the selected project.
Last Published Friday, December 12, 2025
