Select EPS dialog box
Use the Select EPS dialog box to select the EPS node that contains the projects you want to include in time-distributed resource/role assignment, summary resource assignment, and summary role assignment reports.
Display Options bar: Click to change the EPS table display.
EPS table: Lists the ID and name for existing EPS elements. To sort the display, click a column label.
Select: Selects the highlighted EPS node.
Last Published Friday, December 12, 2025
