Select Replacement Role dialog box
Use the Select Replacement Role dialog box to select another role to replace the deleted role.
Display Options bar: Click to change the role display.
Role ID: Lists the ID of each role in your organization. To sort the display, click the Role ID column label.
Role Name: Lists the name of each role in your organization. To sort the display, click the Role Name column label.
Select: Applies your selection and closes this dialog box.
Last Published Friday, December 12, 2025
