Store Period Performance dialog box
Use the Store Period Performance dialog box to store past period actuals for a project. You can select to store period performance for any open project.
Project ID: The project's unique identifier. This field is read-only.
Project Name: The name of the project. This field is read-only.
Selected: Unmark the checkbox for each project you do not want to store period performance for.
Financial Period Calendar: The name of the Financial Period Calendar assigned to the project. This field is read-only.
Financial Period: Double-click to open the Select Financial Period dialog in which you can select a predefined financial period.
Data Date: The current data date of the project. This field is read-only.
Store Now: Click to store period performance for the selected projects.
Note
- If any open project is checked out or read-only, you cannot store period performance.
- When connected to a P6 Professional database: You must have the Add/Edit Activities Except Relationships and Store Period Performance project privileges to store period performance.
- When connected to a P6 EPPM database: You must have the appropriate project privileges as defined in P6 to store period performance.
- The Link actual to date and actual this period units and costs option in the Project Details, Calculations tab, must be selected to store period performance.
Last Published Friday, December 12, 2025
