Using Hint Help
Field descriptions, called Hint Help, are provided for column values in various windows.
To access Hint Help
- Choose View, Hint Help. Move the mouse pointer over any column.
- Choose the Hint Help command again to turn off Hint Help.
Tip
When P6 Professional is connected to a P6 Professional database, you can also press Alt +F1 to access Hint Help.
Last Published Thursday, October 9, 2025
