View budget and spending plan totals
- Choose Enterprise, Projects, then select the EPS node/project for which you want to view budget information.
- Display Project Details, then click the Budget Summary tab to view calculated budget data from the Budget Log and Spending Plan tabs.
Related Topics
Last Published Friday, December 12, 2025
