Viewing summary project information
After you summarize project data, you can easily view this information. For example, add the Planned Value Cost, Earned Value Cost, Actual Cost, Cost Variance, and Schedule Variance columns to the Projects view and group by EPS to quickly see which projects are behind schedule and/or over budget in the enterprise.
The module summarizes two sets of project data: past period actuals and actual to date. You can choose the set of data you want to view in profile options.
- A schedule variance occurs when earned value is less than planned value. Cost variances occur when actual cost exceeds earned value.
Last Published Thursday, April 3, 2025
