Add a project to the EPS hierarchy
Once you set up the EPS structure, you can add an unlimited number of projects as follows:
- Choose Enterprise, Projects, then select the EPS node or root element to which you want to add a project.
- Click  on the Edit Toolbar or choose Edit, Add. on the Edit Toolbar or choose Edit, Add.
- Follow the instructions in the Create a New Project Wizard.
 To quickly add a new project using the default settings, click Finish on the Create a New Project Wizard.
- Use the detail tabs across the bottom of the Project window to add details specific to this project.
Related Topics
Last Published Thursday, October 9, 2025
