Create document categories (P6 Professional Only)
Administration > Defining Administrative Categories (P6 Professional Only) > Document Categories (P6 Professional Only)
You can set up categories to assign to work products and documents.
- Choose Admin, Admin Categories.
 - Click the Document Categories tab, then click Add.
 - Type the name of the new document category.
Tip
To change the order in which document categories are listed, select the document category you want to move, then click Shift Up or Shift Down.
Last Published Thursday, October 9, 2025
