Define a what-if project
P6 Professional enables you to create projects for examining "what-if" scenarios, known as what-if projects. You might choose to copy a project before changing its status to "What-If" so that this change does not impact other projects in the EPS.
- Open the project whose status you want to change to “what-if.”
- Choose Enterprise, Projects and display Project Details.
- Click the General tab.
- Select What-If in the Status field.Note Changing a project's status requires the appropriate access rights.
Related Topics
Last Published Thursday, October 9, 2025
