Edit a work breakdown structure element
- Choose Project, WBS.
- Select the WBS element you want to edit.
 To change the element's position in the WBS, click the appropriate arrow buttons. Note that the maximum number of WBS levels is set in the Data Limits tab of the Admin Preferences dialog box when P6 Professional is connected to a P6 Professional database and is set in P6 Settings page when P6 Professional is connected to a P6 EPPM database.
- Click the Display Options bar and choose Show on Bottom, WBS Details to view or modify information in the General and WBS Milestones tabs.
Tip
You can also directly edit some WBS information in the WBS table by double-clicking the information you want to change.
Last Published Thursday, October 9, 2025
