Edit resource codes
- Choose Enterprise, Resource Codes.
- Click Modify.
- Select the resource code you want to edit.
 To change the resource code's name, type a new name.
 To change the maximum number of characters the code's values may have, specify a new number.
 To change the placement of the code in the list, click Shift Up or Shift Down.
- Click Close.
Tip
If you change a resource code, your changes apply to all resource assignments.
Last Published Thursday, October 9, 2025
