Level selected resources
- Choose Tools, Level Resources.
- Clear the Level All Resources checkbox to level only a subset of all the resources.
- Click Select Resources.
- Mark the checkbox in the Level column next to each resource you want to level, then click OK.
- Click Level.Note - If the Level All Resources checkbox is marked, all the resources will be leveled regardless of the resource selection defined under the Select Resources button.
Last Published Thursday, October 9, 2025
