Select Unit of Measure dialog box
The Select Unit of Measure dialog box displays a list of all valid units of measure that are available to all material resources.
A unit of measure describes the quantity of a particular resource. Labor resources are often measured in units of time, such as hours or days; materials can be measured in cubic or linear feet, or perhaps in tons or kilos; items used one-by-one can be measured individually (EA) or as shipped: a box, a case, a pallet. Money is generally measured in monetary units, such as dollars or yen.
Search: Enter your search criteria in the Search field to search through a long list of available Units of Measure.
Note
- The Unit of Measure field is only available when a resource is designated as a Material Resource.
 - Overtime fields, generally designated for Labor and Nonlabor will be cleared and disabled when Unit of Measure is selected.
Last Published Thursday, October 9, 2025
