Deploying ADM Sessions Using Command-Line Interface
Deploying sessions using the Server Manager (srvrmgr) command-line interface is one of the means of migrating ADM database data types from one Siebel application environment to another. This topic is part of Deploying an ADM Session or Export File, which also provides information about other deployment options.
Before using this deployment option, make sure that an ADM session exists and that the deployment unit XML file has been exported as outlined in the tasks 1 through 6 of Process of Creating Siebel ADM Deployment Units from Database Types.
This procedure runs a workflow process, named UDA Batch Import, on the target environment. This workflow process imports the data into the target environment, based on a session ID provided, using Siebel EAI as the transport. The Server Manager command line can be used to generate export files multiple times and can provide basic automation for the export step.
The Workflow Process Manager component (WfProcMgr) must be running on the target Siebel Server in order for this procedure to run correctly.
To import deployment session file using the Server Manager command-line interface
Make sure that the export deployment file exists in a shared network location.
Note: You do not need to create a deployment session in the target environment to import a deployment session file.Start the Server Manager command-line interface with your user ID in the target system.
For more information about this procedure, see Siebel System Administration Guide.
Verify that the server component Workflow Process Manager (alias WfProcMgr) is online.
If it is not, then enable the Workflow Management component group (alias Workflow) and restart the Siebel Server. For more information about these tasks, see Siebel System Administration Guide.
Enter the following command at the Server Manager command-line interface prompt:
start task for comp WfProcMgr server Siebel_Server_Name with ProcessName="UDA Batch Import", RowID="Session_ID"
where:
Siebel_Server_Name is the name of the Siebel Server.
UDA Batch Import
is the name of the workflow process. This value is case-sensitive.Session_ID is the session ID of the deployment session used to generate the export files.
Note: This session ID does not exist anywhere in the target database. It is the session ID used to export files. This value maps to an .ini file generated during the export.
Check the details of the batch deployment by reviewing the source system EAI queue.
Note: One import step reads all of the previously generated files by the export session executed on the source system.
