Customizing Applets to Capture Signatures for Siebel Mobile Applications
A signature capture is an electronic capture of a user signature. This topic describes how to customize applets to capture signatures in Siebel Mobile applications.
To customize applets to capture signatures for Siebel Mobile applications
Create a new business component and add a new field.
Create a new Signature business component with the values shown in the following table.
Property Value Name
Signature BC
Class
CSSBCBase
Create a new Signature business component field with the values shown in the following table.
Property Value Name
Signature
Type
DTYPE_NOTE
Text Length
16,383
Force Activation
Selected
Create a new Form Applet with the values shown in the following table, adding an _PUI suffix to the name.
Name Class Business Component Signature Form Applet_PUI
CSSFrameBase
Signature BC
Add applet user properties:
In the Object Explorer, expand the Applet tree, and then click Applet User Prop.
In the Applet User Props list, add the following applet user properties as required.
Name Value CanInvokeMethod: ClearSignature
TRUE
Parent BC Name, for example:
For Siebel Pharma, Parent BC Name is: Parent BC Name: Pharma Professional Call - Mobile
For Siebel Service, Parent BC Name is: Parent BC Name: Action
For example:
Action
Signature Field
Signature
Signature Length
1600
Signature Min Length
5
Use Apply Drilldown
Y
Use Cancel Drilldown
Y
Add controls:
In the Object Explorer, click Control.
In the Controls list, add the following controls.
Name Description Clear Signature
Set the MethodInvoked property to ClearSignature.
Address
Set the Field property to Address.
Note: You can create other fields such as Contact First Name in addition to the Address field as required.
Signature Capture
Set the following properties:
Set the Field property to Signature.
Set the HTML Type property to InkData.
Apply Signature
Set the MethodInvoked property to ApplySignature.
Cancel Signature
Set the MethodInvoked property to CancelSignature.
Add an applet Web template:
In the Object Explorer, click Applet Web Template.
In the Applet Web Templates list, right-click and select new record.
Set the following properties.
Property Value Name
Edit
Type
Edit
Web Template
SIA Applet Form Grid Layout - No Menu_OUI
Create the following new drilldown objects:
In the Object Explorer, click Drilldown Object.
In the Drilldown Objects list, configure the values shown in the following table as required for the Apply Drilldown and the Cancel Drilldown drilldown objects.
Note: The values shown in the following table (for View, Business Component, and so on) are examples only - you can choose a different view and business component as required.Name Hyperlink Field View Source Field Business Component Destination Field Apply Drilldown
Address
LS Pharma Professional Call Execute View - Mobile
Activity Id
Id
Cancel Drilldown
Address
Activity Id
Id
Expose the Controls in the Applet Web Template item as follows:
In the Object Explorer, click Applet.
Select Applet "Signature Form Applet_PUI", then right-click and select Edit Web Layout.
Select Edit mode.
Select and move the Signature field and the Apply Signature, Cancel Signature, and Clear Signature buttons on the Web Layout.
Compile your modifications.
Add the applet Signature Form Applet_PUI to the manifest administration as follows:
Log in to the client with administrative privileges.
Navigate to the Administration - Application screen, and then the Manifest Administration view.
Under UI Objects, create a new record with the following values:
Interactive Flag Type Usage Type Name N
Applet
Physical Renderer
Under Object Expression, add the following child applet for the record created in Step c.
Interactive Flag Expression Level N
<Empty>
2
N
Mobile
1
Under Files, set the following file values:
Interactive Flag Name N
3rdParty/jquery.signaturepad.min.js
N
siebel/signviewpr.js
Applet
Presentation Model
Under Object Expression, add the following child applet for the record created in step f.
Mobile
1
siebel/signviewpm.js
Test your modifications.
Log in to the Siebel Open UI client.
Navigate to a view where the Signature Form Applet_PUI is exposed.
Verify that the Signature Capture view applet displays correctly - that is, according to the customizations detailed in this procedure.
