Example of Restricting Navigation Options
The example in this topic describes how to restricts the Tree navigation option to only the ADMIN user in Siebel Open UI.
This topic gives one example of restricting navigation options. You might use this feature differently, depending on your business model.
To restrict the Tree navigation option to only the ADMIN user
Create an expression that restricts availability to administrator only:
Log in to a Siebel client with administrative privileges.
Navigate to the Administration - Application screen, and then the Manifest Expressions view.
Click the plus (+) icon create a new expression.
Specify the following in the Name field:
Admin Only
Specify the following in the Expression field:
GetProfileAttr('Login Name') = 'ADMIN'
Create a copy of the NAVIGATION_TREE object:
Navigate to the Administration - Application screen, and then the Manifest Administration view.
In the UI Objects list, search with the following specifications:
Field Value Type
Navigation
Usage Type
Physical Renderer
Name
NAVIGATION_TREE
Select the NAVIGATION_TREE record.
Select the Edit menu, then Copy Record.
Edit the new NAVIGATION_TREE record:
Select the copy of the NAVIGATION _TREE record.
Click the plus (+) icon in Object Expression applet.
In the Expression field, specify the expression Admin Only.
Click the plus (+) icon in the Files applet to add the following file:
jsTreeCtrl.js
Verify your work:
Log out of the client, and then log back into the client as a user other than ADMIN.
Navigate to the User Preferences screen, then the Behavior view.
Verify that the only the following two options are available in the Navigation Control drop-down menu:
Side Menu
Tab
Log out of the client, and then log back into the client as the ADMIN user.
Verify that the only the following three options are available in the Navigation Control drop-down menu:
Side Menu
Tab
Tree
