Operations You Can Customize When Clients Are Offline
You can customize the following operations when the client is offline:
Create, read, update, and delete parent objects and child objects.
Modify user interface behavior according to data characteristics, such as read only, required, and can invoke. Siebel Open UI uses the IsReadonly, IsRequired, and CanInvoke methods to achieve this behavior.
You can customize the following items when the client is offline:
Association applets
Applet menu and applet menu items
Pick applets
Picklists
Static picklists
Error statuses
Static drill downs
Expressions
Searches
