Sample Code for Invoking Methods of Web Engine HTTP TXN Business Service
This topic contains the sample code for invoking the methods of the Web Engine HTTP TXN Business Service and writing the results to a text file. For more information, see Example of Using Web Engine HTTP TXN Business Service.
Add the following sample code to the WebApplet_InvokeMethod event:
function WebApplet_InvokeMethod (MethodName)
var fp = Clib.fopen('testfile.txt','a');
if ( fp == null )
TheApplication().RaiseErrorText(" ERROR Opening File ")
else
var oBS = TheApplication().GetService('Web Engine HTTP TXN');
var Inputs = TheApplication().NewPropertySet();
var Outputs = TheApplication().NewPropertySet();
var Headers = TheApplication().NewPropertySet();
var Cookies = TheApplication().NewPropertySet();
var tmpCookie = TheApplication().NewPropertySet();
Clib.fputs('=====================================\n',fp);
Clib.fputs('WebApplet InvokeMethod event:\n',fp);
Clib.fputs('\n',fp);
Clib.fputs('Method: GetAllRequestCookies\n',fp);
Inputs.Reset();
Outputs.Reset();
oBS.InvokeMethod ( 'GetAllRequestCookies', Inputs, Outputs);
WebApplet_OutputPropertySet(Outputs, 0, fp);
Clib.fputs('Method: GetAllRequestHeaders\n',fp);
Inputs.Reset();
Outputs.Reset();
oBS.InvokeMethod ('GetAllRequestHeaders', Inputs, Outputs);
Clib.fputs('Method: GetAllRequestParameters\n',fp);
Inputs.Reset();
Outputs.Reset();
oBS.InvokeMethod ('GetAllRequestParameters', Inputs, Outputs);
Clib.fputs('Method: GetAllResponseCookies\n',fp);
Inputs.Reset();
Outputs.Reset();
oBS.InvokeMethod ('GetAllResponseCookies', Inputs, Outputs)
Clib.fputs('Method: GetAllResponseHeaders\n',fp);
Inputs.Reset();
Outputs.Reset();
oBS.InvokeMethod ('GetAllResponseHeaders', Inputs, Outputs);
Clib.fputs('Method: GetAllServerVariables\n',fp);
Inputs.Reset();
Outputs.Reset();
oBS.InvokeMethod ('GetAllServerVariables', Inputs, Outputs);
Clib.fputs('Method: GetRequestCookies\n',fp);
Inputs.Reset();
Outputs.Reset();
Inputs.SetProperty ('MY-COOKIE', '');
Inputs.SetProperty ('TestCookie', '');
Inputs.SetProperty ('Test1Cookie', '');
oBS.InvokeMethod ('GetRequestCookies', Inputs, Outputs);
Clib.fputs('Method: GetRequestHeaders\n',fp);
Inputs.Reset();
Outputs.Reset();
Inputs.SetProperty ('MyHEADER', '');
Inputs.SetProperty ('MY_TEST', '');
Inputs.SetProperty ('CONTENT-TYPE', '');
Inputs.SetProperty ('CONTENT-LENGTH', '');
oBS.InvokeMethod ('GetRequestHeaders', Inputs, Outputs);
Clib.fputs('Method: GetRequestInfo\n',fp);
Inputs.Reset();
Outputs.Reset();
oBS.InvokeMethod ('GetRequestInfo', Inputs, Outputs);
Clib.fputs('Method: GetRequestParameters\n',fp);
Inputs.Reset();
Outputs.Reset();
Inputs.SetProperty ('TestQstr', '');
Inputs.SetProperty ('SWEActiveView', '');
Inputs.SetProperty ('SWECmd', '');
Inputs.SetProperty ('SWEMethod', '');
Inputs.SetProperty ('TestParam', '');
oBS.InvokeMethod ('GetRequestParameters', Inputs, Outputs);
Clib.fputs('Method: GetResponseCookies\n',fp);
Inputs.Reset();
Outputs.Reset();
Inputs.SetProperty ('My-Test-COOKIE', '');
Inputs.SetProperty ('_sn', '');
oBS.InvokeMethod ('GetResponseCookies', Inputs, Outputs);
Clib.fputs('Method: GetResponseHeaders\n',fp);
Inputs.Reset();
Outputs.Reset();
Inputs.SetProperty ('Content-Language', '');
Inputs.SetProperty ('MyHeader', '');
oBS.InvokeMethod ('GetResponseHeaders', Inputs, Outputs);
Clib.fputs('Method: GetResponseInfo\n',fp);
Inputs.Reset();
Outputs.Reset();
oBS.InvokeMethod ('GetResponseInfo', Inputs, Outputs);
Clib.fputs('Method: GetServerVariables\n',fp);
Inputs.Reset();
Outputs.Reset();
Inputs.SetProperty ('AUTH-USER-ID', '');
Inputs.SetProperty ('SERVER-NAME', '');
oBS.InvokeMethod ('GetServerVariables', Inputs, Outputs);
Clib.fputs('Method: GetWebSessionInfo\n',fp);
Inputs.Reset();
Outputs.Reset();
oBS.InvokeMethod ('GetWebSessionInfo', Inputs, Outputs);
Clib.fputs('Method: SetResponseCookies\n',fp);
Inputs.Reset();
Outputs.Reset();
tmpCookie = null;
tmpCookie.SetType ('My_Test_Cookie');
tmpCookie.SetValue ('Cookie Value for My_Test_Cookie');
tmpCookie.SetProperty ('Max-Age', '23434343');
tmpCookie.SetProperty ('Domain', '.example.com');
tmpCookie.SetProperty ( 'Path', 'eapps/test/cookie/path');
Inputs.AddChild (tmpCookie);
tmpCookie = null;
tmpCookie.SetType ('Another_Cookie');
tmpCookie.SetValue ('Cookie Value for Another_Cookie');
tmpCookie.SetProperty ('Domain', 'esales.example.com');
tmpCookie.SetProperty ('Path', 'esales/cookie/path');
oBS.InvokeMethod ('SetResponseCookies', Inputs, Outputs);
Clib.fputs('------------------------------------\n',fp);
Clib.fputs('Input Cookies\n',fp);
WebApplet_OutputPropertySet(Inputs, 0, fp);
oBS.InvokeMethod ('GetAllResponseCookies', Inputs, Outputs);
Clib.fputs('Output Cookies\n',fp);
Clib.fputs('Method: SetResponseHeaders\n',fp);
Inputs.Reset();
Outputs.Reset();
Inputs.SetProperty ('MyHeader', 'THIS is MyHeader');
oBS.InvokeMethod ('SetResponseHeaders', Inputs, Outputs);
Clib.fputs('Input Headers\n',fp);
Clib.fputs('Output Headers\n',fp);
Clib.fputs('Method: SetResponseInfo\n',fp);
Inputs.Reset();
Outputs.Reset();
Headers.Reset();
Cookies.Reset();
Headers.SetType ('HEADERS');
Headers.SetProperty ('ABC_RESPONSE_HEADER1', 'RESPONSE_HEADER1 Value');
Headers.SetProperty ('ABC_RESPONSE_HEADER2', 'RESPONSE_HEADER2 Value');
Headers.SetProperty ('ABC_RESPONSE_HEADER3', 'RESPONSE_HEADER3 Value');
Headers.SetProperty ('ABC_RESPONSE_HEADER4', 'RESPONSE_HEADER4 Value');
Inputs.AddChild( Headers);
Cookies.SetType('COOKIES');
tmpCookie = null;
tmpCookie.SetType ('My_Test_Cookie2');
tmpCookie.SetValue ( 'Cookie Value for My_Test_Cookie2');
tmpCookie.SetProperty ( 'Max-Age', '23434343');
Cookies.AddChild (tmpCookie);
tmpCookie = null;
tmpCookie.SetType ('Another_Cookie2');
tmpCookie.SetValue ('Cookie Value for Another_Cookie2');
Inputs.AddChild (Cookies);
oBS.InvokeMethod ('SetResponseInfo', Inputs, Outputs);
Clib.fputs('Input Info\n',fp);
Clib.fputs('Output Info\n',fp);
Clib.fclose(fp);
