CME Order Management
This ERD (see the following figure) illustrates order management. Companies provide products and services to their customers over an extended period of time. Quotes and orders are used to capture the changes to a customer's installed services. The cycle starts when a customer requests the initial installation of a product or service in the form of a quote. The quote is converted to an order and that order is provisioned. At that time, the products and services described in the order are converted into assets associated with the customer's account. Subsequent changes to the configuration, disconnect instructions, or additions to the installed assets are captured in further quotes and orders. Order synchronization failures can also be tracked.
CME Order Management: This image is described in the surrounding text.
The following table lists the entities in this ERD and their corresponding tables.
Entity Table
Account
S_ORG_EXT, S_PARTY
Asset
S_ASSET
Asset Attribute
S_ASSET_XA
Order
S_ORDER
Order Item
S_ORDER_ITEM
Order Item Attribute
S_ORDER_ITEM_XA
Product or Service
S_PROD_INT
Quote
S_DOC_QUOTE
Quote Item
S_QUOTE_ITEM
Quote Item Attribute
S_QUOTE_ITEM_XA
Failed Service Order
S_SRV_ORD_FAIL
Service Request
S_SRV_REQ
