Configuring Notification Settings for Siebel Mobile
Note: You must be connected to the Siebel Server to perform this task.
You use the Notifications option under Settings to configure the settings for notification messages in your Siebel Mobile application.
To configure notification settings for Siebel Mobile
  1. Tap Settings (the photo icon) on the application banner, and then select the Settings option.
  2. Tap Notification (the exclamation mark icon), and then complete the fields shown in the following table as required.
    Field
    Description
    Example Value
    Update Interval (Seconds)
    Type the time interval in seconds at which you want notifications to refresh.
    120
    Prefix of Normal Priority Message
    Type the text to appear before a normal-priority message. This aids accessibility. For example, a letter is useful if you have difficulty distinguishing the colors of the messages.
    N
    Prefix of High Priority Message
    Type the text to appear before a high-priority message. This aids accessibility. For example, a letter is useful if you have difficulty distinguishing the colors of the messages.
    H
    Prefix of Urgent Priority Message
    Type the text to appear before an urgent-priority message. This aids accessibility. For example, a letter is useful if you have difficulty distinguishing the colors of the messages.
    U
  3. Save the changes when finished.
