Configuring Integration Components for Effective Dating on Fields
You can enable effective dating on a field in an existing integration object if the corresponding field in the business component is effective dating-enabled. You enable fields for effective dating through the Siebel Web Client administration Effective Dating screen.
To enable effective dating on fields
In the Siebel Web Client, navigate to Administration - Effective Dating, then Field.
In the Effective Dating Buscomp list, select the required business component.
The list displays the fields already enabled for ED.
If you want enable effective dating field not present in this list, click New, then in the Field field click the Select button.
In the Business Component Fields window select the required field, then click OK.
This enables the fields for ED.
You use Siebel Tools to synchronize the object from your current repository, with its underlying business object in the Siebel database which contains the new EDEnabled user property. For more information on synchronizing integration objects, see Synchronizing Integration Objects.
To enable effective dating on an integration object
In Siebel Tools, select the integration object you want to enable for effective dating.
Click the Synchronize button in the Integration Objects list.
The Integration Object Synchronize wizard appears.
Click the plus symbol to display all the related integration components.
Uncheck the boxes beside the objects and components you do not want to include in the synchronization of your Siebel integration object.
Locate the integration component containing the effective dating-enabled fields and drill down on it.
Click the plus symbol to display all the user properties of the field.
Locate the EDEnabled user property from the list and add it to the repository side.
Review the summary, and if changes are needed, click Back and make the needed changes.
If no changes are needed, click Finish to synchronize the Siebel integration object and the Siebel business object.
