Actual and Abbreviation Field 1
Use this user property to define the actual field and the corresponding abbreviation in the Function Space Diary.
Actual and Abbreviation Field 1 Description
Value
Function Type;Function Type Abbr
Parent Object Type
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet applets
Usage
The TNT SHM Function Booking VBC business component has been configured in the Item Business Component applet user property for all the parent object types (mentioned in the previous row).
The first part of the user property value represents the actual field value of the TNT SHM Function Booking VBC business component. The second part of the user property value represents the abbreviation of the corresponding actual field.
If the value is available, then the corresponding abbreviation is displayed in the label and tooltip in the Function Space Diary in place of the actual field value.
