AddToCart Proxy Buscomp2
Use this user property to get the business component instance in C++ code to evaluate defined search criteria and search for items.
| Property | Description/Value |
Value |
Internal Product Popup |
Parent Object Type |
Quick Add business component |
Usage |
The value of this user property is business component. This user property gets the business component instance in C++ code to evaluate defined search criteria, search items, and add the selected items to the function line items. |
