CanInvokeMethod: CopyRecord
Use this user property to disable the Copy Record functionality for records in the line items applet.
| Property | Description/Value |
Value |
[TNT Disable New Delete Flag] AND [Id] IS NOT NULL |
Parent Object Type |
TNT SHM Function Line Items List Applet, TNT SHM Order Line Item List Applet, TNT SHM Event Check Line Item List Applet, and TNT SHM Event Check Order Line Item Form Applet applets |
Usage |
Disables the Copy Record functionality when no records appear in the line items applet. |
