Double Click Applet Method
Use this user property to specify the method to call on a double-click event.
| Property | Description/Value |
Value |
AddProducts |
Parent Object Type |
TNT Menu Product Pick Applet applet, TNT Package Product Pick Applet apĀplet |
Usage |
When a user double-clicks one of the parent objects, the selected record is added to its originating or parent applet. The value of this user property is AddProducts, which is a custom method. If you do not use the double-click event, this user property can be deactivated. |
