Enable Color Icon
Use this user property to enable or disable color coding in the Function Space Diary.
| Enable Color Icon | Description |
Value |
Y |
Parent Object Type |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet applets |
Usage |
Turns color coding on or off in the Function Space Diary. If the value is N, no color icons are displayed. |
