Enable Sub Function Dependency At Detail Function
Use this user property to define a business object name to make technical decisions in C++ code.
| Enable Sub Function Dependency At Detail Function | Description |
Value |
N |
Parent Object Type |
TNT SHM Function Booking VBC business component |
Usage |
This user property is used in C++ code. If the value is Y, then dependencies for the subfunction will be created and displayed at the detail function booking level. If the value is N, then dependencies for the subfunction will not be created and displayed at the detail function booking level. |
