Function Drop Conflict Popup Default
If the booking conflict pop-up applet is not specified, this user property is used to specify the default operation to be performed when a booking conflict occurs.
| Function Drop Conflict Popup Default | Description |
Value |
OptionFunction |
Parent Object Type |
TNT SHM Function Space Diary Total Availability Applet, TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary |
Usage |
If the booking conflict pop-up applet is not specified, this user property is used to specify the default operation to be performed when a booking conflict occurs. |
