Line Items BO Name: TNT SHM Order Entry
Use this user property to define the business object name to make technical decisions in C++ code.
| Property | Description/Value |
Value |
TNT SHM Order Entry |
Parent Object Type |
TNT SHM Order Item business component |
Usage |
Defines the business object name to make technical decisions in C++ code. This user property is active only if the business component is associated with the defined business object. |
