Marking Function Spaces as Unavailable or Out Of Order
Function space is considered out of order when there is a physical issue that prevents the property from using the space. For example, if a water pipe breaks, flooding a function space, the function space is flagged as out of order for a specified period of time.
Function space is considered unavailable when the space is being used for other purposes, or the operations management of the property decides that it does not make fiscal sense to have the space available for sale as function space. For example, a hotel restaurant is open for dinner from 4 to 11 P.M. During that period, the restaurant is unavailable for sale as function space because it is being used to serve all the guests of the hotel and the local population. The function space of the restaurant is designated as unavailable from 4 to 11 P.M. each day. However, the space might be available for sale at other times of the day.
Because unavailable and out-of-order function space is a revenue issue, the Property Pricing Admin screen is used. Revenue managers typically designate the function space as out of order and unavailable. When a function space is flagged as unavailable or out of order, then it cannot be included in a quote at the specified time.
This task is a step in Administering Function Space Pricing.
To mark a function space as unavailable
Navigate to the Property Pricing Admin screen, then the Properties view.
In the Properties list, select the required property, and click the link in the Property Name field.
Click the Unavailable view tab.
In the Unavailable list, create a new record, complete the fields, and save the record.
The following table describes some of the fields.
Field Comments Function Space
Select the function space to flag as unavailable.
Booking Type
This field is automatically populated as Unavailable.
Frequency
Select the day on which the function space will be unavailable.
Recur Start Date
The date from which the function space will be unavailable.
Start Day
This field is automatically populated when the Recur Start Date field is completed.
Recur Start Time
The time at which the function space will become unavailable.
Recur End Date
The date from which the function space will no longer be unavailable.
End Day
This field is automatically populated when the Recur End Date field is completed.
Recur End Time
The time at which the function space is no longer unavailable.
Reason
Select a reason why the function space is unavailable. This list of values is administered through the Administration - Data screen, List of Values view.
To mark a function space as out of order
Click the Out of Order view tab.
In the Out of Order list, create a new record, complete the fields, and save the record.
Field Comments Start Date Time
The date and time from which this function space is out of order.
Start Day
This field is automatically populated when the Start Date Time field is completed.
End Date Time
The date and time on which this function space will no longer be out of order.
End Day
This field is automatically populated when the End Date Time field is completed.
Reason
Select a reason why the function space is out of order.
Function Space
Booking Type
This field is automatically populated as Out of Order.
Created
The date on which this record was created.
Created By
The User Id of the user who created this record.
