Modifying Adjustment Amounts for a Matrix Series
On occasion, an administrator might want to increase or decrease all the adjustment amounts associated with a matrix series. The administrator can do this using the Transform button.
To modify adjustment amounts for a matrix series
Navigate to the Property Pricing Admin screen, Properties, and then the Matrix Series view for the required property record.
Select the required series record, and click Transform. The Matrix Transform dialog box is displayed.
In the Transform field, enter the amount by which the adjustment amounts must be transformed. For example, to increase adjustment amounts by ten percent, enter 110%, or to decrease adjustment amounts by ten percent, enter 90%.
Do one of the following:
To apply the adjustment to Price Overrides only, make sure that the Price Override Only check box is selected.
To apply the adjustment to all adjustment amounts, make sure that the Price Override Only check box is deselected.
Click Transform. The transformation is applied to the adjustment amount fields for Account and Segment matrices.
Select the matrix series and scroll down to the Price Details list.
In the Price details list, add a record.
Complete the fields and save the record.
Repeat Step 7 through Step 8 to create additional Price Details records.
