Modifying Formats and Mappings for Hospitality Report Fields
Administrators can modify formats for any report field. This topic describes how to modify field mappings and how to format fields for Hospitality reports.
To modify formats and mappings for Hospitality report fields
Modify the report RTF file by completing the following steps.
Navigate to the file in the following directory:
$SiebelRoot$\XMLP\TemplatesSelect and open the RTF file for the report whose field mappings to modify.
Make the necessary field mapping and formatting modifications to the file.
Save the file.
Generate a report XLF file from the report RTF file by completing the following steps.
Open the report RTF file.
Navigate to Oracle BI Publisher, Translate Template, and then Extract Text.
Note: You can access Oracle BI Publisher only if you install Business Intelligence Desktop, a Business Intelligence Add-in for Microsoft Word.Save the report RTF file as a XLF file in the following directory:
$SiebelRoot$\XMLP\XLIFF\Language.
For more information about modifying reports templates and Oracle BI Publisher Add-in for Microsoft Word, see Siebel Reports Guide.
In Siebel Hospitality, navigate to the Administration - BIP Reports screen, then the Report Template Registration view.
In the Report Template Registration list, complete the following steps.
Query for and select the report with the Report Name field value of the report title.
In the Template field, click the select button, navigate to the report RTF file and click Add.
In the XLIFF field, click the select button, navigate to the report XLF file and click Add.
Click Upload Files.
