Named Method 11
Use this user property to update the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change.
| Named Method 11 | Description |
Value |
"Update Sub Function", "INVOKESVC", "TNT SHM Function", "TNT SHM Day Number", "UpdateSubFunction" |
Parent Object Type |
TNT SHM Function business component |
Usage |
Updates the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change. This user property works with the On Field Update Invoke 19 user property. |
