Named Method 17
Use this user property to update the Quantity if Guaranteed/Projected/Expected Num changes in the Parent BC TNT SHM Function.
| Property | Description/Value |
Value |
"UpdateField", "SET", "Quantity Requested", [QuantityCalc] |
Parent Object Type |
TNT SHM Order Item business component |
Usage |
Updates the Quantity of TNT SHM Order Item if Guaranteed/Projected/Expected Num changes in the parent business component TNT SHM Function. |
