Named Method: NavigateToView
Use this user property to navigate to another view with search or sort specifications.
Value |
"INVOKESVC", "TNT SHM Workflow UI Service", "GotoView", "'View'", "'TNT SHM Category Line Items View'", "'Sort Spec'", "'TNT Grouping'", "'Search Spec'", "[TNT MM Search Spec]", "'Business Component'", "''", "'Row Id'", "''" |
Parent Object Type |
TNT SHM Function Line Items List Applet applet |
Usage |
Navigates to another view with search or sort specifications. By default, the destination view is TNT SHM Category Line Items View, which is defined after the View parameter. |
