Pivot 0 BC Sort Spec
Use this user property to define the sort specification while displaying the available data.
| Pivot 0 BC Sort Spec | Description |
Value |
Start Date, Room Type (DESCENDING), Room Name |
Parent Object Type |
TNT SHM SR Inventory Dync business component |
Usage |
This user property is used to define the sort specification while displaying the available data. The sort specification can be changed by modifying the value with appropriate fields. |
