Pivot 0 BC Sort Spec
This user property contains the sort specification to apply to the business component in which the displayed data is stored.
| Pivot 0 BC Sort Spec | Description |
Value |
Start Date, Room Type (DESCENDING), Room Name |
Parent Object Type |
TNT SHM SR Inventory Dync |
Usage |
This user property contains the sort specification to apply to the business component in which the displayed data is stored. |
