Product BC Name: TNT Function Line Item Quick Entry View
Use this user property to pass the Product business component name to the C++ code.
| Property | Description/Value |
               Value  |
               Internal Product Popup  |
               Parent Object Type  |
               Internal Product Popup business component  |
               Usage  |
               Retrieves the business component instance in C++ code while adding items to the function line items through the Search Add applet. The second part of the user property name designates the view context. If the active view is the TNT Function Line Item Quick Entry view, then the Internal Product Popup business component instance evaluates defined search criteria and gets the items.  |
